JimmyBSwe
Mar 11, 2024Aspirant
How do I turn my Orbi RBR350 into a Access Point?
Hello! I already think this thread exists but I can't find it! I would like to turn my Orbi RBR350 router into an Access Point but can't find a guide on how to do this.Today I have an RBR750 as ...
- Mar 11, 2024
JimmyBSwe wrote:
I can connect my games and tv devices to the main router via network cable through the RBR350, the RBR350 will not be used for anything else, I don't even want it to send out any signal so other devices can connect to it wirelessly.. Is this possible or not?
A $20 gigabit Ethernet switch will be a cleaner solution, plus offer more ports (8 ports instead of 3), and take up less space.
It is impossible to disable the WiFi radios on Orbi equipment. (They are, after all, WiFi routers.) What you could do is:
- Change the 2.4G and 5G channels to as far as possible from the 750 as possible.
- Go to the Advanced Tab, Advanced Settings, Wireless Settings and change the Transmit Power setting to the smallest possible value (which I think is 25%)
I would go with the Ethernet switch
JimmyBSwe
Thanks for quick reply!
So, if it works as I have thought, my thought is that my RBR750 is the main router and my two RBS350 satellites will be wirelessly linked to it just as they are today and my RBR350 router that is not in use today will be connected to my RBR750 router via network cable only so I can connect my games and tv devices to the main router via network cable through the RBR350, the RBR350 will not be used for anything else, I don't even want it to send out any signal so other devices can connect to it wirelessly.. Is this possible or not?
THX
Mar 11, 2024Guru - Experienced User
What FW is currently loaded on the RBR750?
Be aware that the RBR750 and RBS350 FW will be to all be using the following version if you wish to use the RBS350s with a RBR750 unit:
- JimmyBSweMar 11, 2024Aspirant
I use FW v4.6.14.3 on the RBR750 and the same om RBS350, I've been using this combination for a while already, it's just the RBR350 router that I want to connect to the existing system so I get more network ports to connect my game-consoles and TV-box to..
- FURRYe38Mar 11, 2024Guru - Experienced User
You could however would be needing to be in AP mode and using different channels an SSID name is all.
