GregS_from_MI
Dec 17, 2021Apprentice
How do you turn off G on RBK753
I just purchased a AX4200 (RBK753) Orbi Mesh system. System setup was easy and I was up and running in no time. I just purchased a Wansview Q5 1080P indoor camera for our house. As you know, many ...
- Dec 18, 2021
GregS_from_MI wrote:
I tried to connect the camera from the manual where you use the Soft-AP mode. I got the new connection and connected but the app never let me continue the pairing. It just set on the step where I connected to the new WVC network.
So the Wansview app is stuck on step 4 and will not advance to step 5, correct?
https://wansview.com/uploadfiles/2019/04/20190419162420335.pdf
Never gets to the step of creating a QR code?
Dec 17, 2021Guru - Experienced User
So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS for now. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
- GregS_from_MIDec 18, 2021Apprentice
I've read others say the same thing but no one tells where you reduce the power level of 5Ghz. I've look for that but it isn't real obvious to me.
I'm willing to give it a try if I knew where to adjust it. I'll look again in all the menus.
Thanks
FURRYe38 wrote:So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS for now. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Ok, I think I found it. I'll give it a try and check back later.
Thx
- FURRYe38Dec 18, 2021Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
FURRYe38 wrote:Under Advanced Tab/Advanced Settings/Wireless Settings
I found it, so here is what I changed on that screen. I changed the power on the 5G from 100% to 25% and unchecked the other box on that setting, correct?
Regardless, I couldn't connect the camera with those updated settings.
