GregS_from_MI
Dec 17, 2021Apprentice
How do you turn off G on RBK753
I just purchased a AX4200 (RBK753) Orbi Mesh system. System setup was easy and I was up and running in no time. I just purchased a Wansview Q5 1080P indoor camera for our house. As you know, many ...
- Dec 18, 2021
GregS_from_MI wrote:
I tried to connect the camera from the manual where you use the Soft-AP mode. I got the new connection and connected but the app never let me continue the pairing. It just set on the step where I connected to the new WVC network.
So the Wansview app is stuck on step 4 and will not advance to step 5, correct?
https://wansview.com/uploadfiles/2019/04/20190419162420335.pdf
Never gets to the step of creating a QR code?
Dec 17, 2021Guru - Experienced User
So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS for now. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
GregS_from_MI
Dec 18, 2021Apprentice
FURRYe38 wrote:So you might want to also change the power output of the 5Ghz radio to 25%. Turn OFF the RBS for now. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Ok, I think I found it. I'll give it a try and check back later.
Thx
- FURRYe38Dec 18, 2021Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
- GregS_from_MIDec 18, 2021Apprentice
FURRYe38 wrote:Under Advanced Tab/Advanced Settings/Wireless Settings
I found it, so here is what I changed on that screen. I changed the power on the 5G from 100% to 25% and unchecked the other box on that setting, correct?
Regardless, I couldn't connect the camera with those updated settings.
