GregS_from_MI
Dec 17, 2021Apprentice
How do you turn off G on RBK753
I just purchased a AX4200 (RBK753) Orbi Mesh system. System setup was easy and I was up and running in no time. I just purchased a Wansview Q5 1080P indoor camera for our house. As you know, many ...
- Dec 18, 2021
GregS_from_MI wrote:
I tried to connect the camera from the manual where you use the Soft-AP mode. I got the new connection and connected but the app never let me continue the pairing. It just set on the step where I connected to the new WVC network.
So the Wansview app is stuck on step 4 and will not advance to step 5, correct?
https://wansview.com/uploadfiles/2019/04/20190419162420335.pdf
Never gets to the step of creating a QR code?
GregS_from_MI
Dec 18, 2021Apprentice
Dec 18, 2021Guru - Experienced User
Did you turn OFF the other RBS while working with the camera?
Just curious, if you temporarily set WPA security to NONE, does the camera connect then?
Re-enable after testing.
- GregS_from_MIDec 18, 2021ApprenticeYes I did shut off both satellites.
The camera app won't let me continue because it thinks I'm on the 5Ghz channel. I even tried to connect through a connection called Soft-AP on the camera, but the app didn't me to finish the setup on the alternate connection. I'll pursue the camera tech support to see if I can get a resolution.- FURRYe38Dec 18, 2021Guru - Experienced User
If you turned down the 5Ghz power output to 25%, you may need to walk out a bit with your setup wifi mobile phone to see if it will connect to the 2.4Ghz radio...disable the wifi on the device for 5 seconds then back ON.
The camera app won't let me continue because it thinks I'm on the 5Ghz channel. I even tried to connect through a connection called Soft-AP on the camera, but the app didn't me to finish the setup on the alternate connection. I'll pursue the camera tech support to see if I can get a resolution.- GregS_from_MIDec 18, 2021ApprenticeFURRYe38
Good point, I didn't shut off the wifi on the phone after I turned the power down on the 5Ghz channel.
I'll keep that in my for the next time.
