GregS_from_MI
Dec 17, 2021Apprentice
How do you turn off G on RBK753
I just purchased a AX4200 (RBK753) Orbi Mesh system. System setup was easy and I was up and running in no time. I just purchased a Wansview Q5 1080P indoor camera for our house. As you know, many ...
- Dec 18, 2021
GregS_from_MI wrote:
I tried to connect the camera from the manual where you use the Soft-AP mode. I got the new connection and connected but the app never let me continue the pairing. It just set on the step where I connected to the new WVC network.
So the Wansview app is stuck on step 4 and will not advance to step 5, correct?
https://wansview.com/uploadfiles/2019/04/20190419162420335.pdf
Never gets to the step of creating a QR code?
GregS_from_MI
Dec 18, 2021Apprentice
CrimpOn
Dec 18, 2021Guru - Experienced User
- GregS_from_MIDec 18, 2021ApprenticeI finally made it through the Soft-AP alternate connection.
Yes I did make it to the step to scan the code, and I was able to connect to the WVC network but it got stuck there. Reset everything and tried it again and made it through. Camera finally connected.
Thx.- CrimpOnDec 18, 2021Guru - Experienced User
When I have decoded similar QR codes, all they contain are the SSID and password of the WiFi system.
