Tajee's avatar
Tajee
How does the RBKE960 assign clients?
I have devices that are 2-3 feet from the satellites and 75% of those devices are connecting to the main router which is downstairs and 100ft away. Why are they not grabbing onto the closest satellite?
  • CrimpOn's avatar
    CrimpOn
    Have these devices been powered off and back on since the Orbi network was activated?
      • CrimpOn's avatar
        CrimpOn
        Tajee wrote:
        Most likely no.
        What would be the harm in discovering what happens if they are?
  • FURRYe38's avatar
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
