korzonek
Sep 17, 2020Follower
How extend outdoor WiFI of Orbi AX4200 outdoor
I bought Orbi WIFI 6 System (RBK753) AX4200 and would like to extend its WIFI coverage to my garden. What is the best way to do it? Does Orbi Outdoor stallite RBS50Yv2 work with my system?
Sep 17, 2020Guru - Experienced User
NG forum moderator mentioned that you can use the RBSY unit with Orbi AX only if you install the RBSY Extender mode FW on the RBSY.
korzonek wrote:I bought Orbi WIFI 6 System (RBK753) AX4200 and would like to extend its WIFI coverage to my garden. What is the best way to do it?
