mattinson
Oct 11, 2021Aspirant
how good is the ORBI tri band 6 ?
Hi Wise ones... We are running out of ideas to get a decent internet connection to the attic room and looking for some advice. We have 500mb line and have been trying various powerline options, bu...
mattinson
hi,
the house is 3500 sq ft. and solid brick construction with wooden floors and sound dampening insulation in the attic. The virgin router is located in the corner of the lounge and the furthest point from the attic where the PC and TV is located. Unfortunately the router cant be moved. The hope is a daisy chain of 3 orbi satelites on each floor will give a decent enough and reliable connection.
Oct 11, 2021Guru - Experienced User
Solid brick interior walls?
Ouch. Brick does a great job of blocking wifi.
there's a chance it *might* work but I'd buy it from someone who has a generous return policy.
Its a lot of $ to invest in *might* work.
