wififast
Aug 19, 2020Aspirant
How many RBS850 satellites will a RBR850 router support
How many RBS850 satellites will a RBR850 router support? I have 3 satellites and tried to add a 4th. Was not able. Is there a limit on satellites for the AX6000?
Aug 19, 2020Guru - Experienced User
Supposedly 6:
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
Not sure if this works for sure.
Be sure all RBS and the RBR are using same version of FW.
wififast
Aug 20, 2020Aspirant
Thanks. Can only get 3 satellites to work. Maybe it is an issue with daisy chaining more than two satellites. Did live chat with support. Said router only would support 3 satellites. Have sent email request to Support. No response yet.
