Rikerrock
Jun 27, 2020Tutor
How much faster/better aer the Wifi 6 orbis vs. older one?
I have the older orbi three unit system from costco Rbr50 i think with two sats. All gigabit wired to eachother. How much better is the orbi ax in same wiring setup. Thanks
Rikerrock
Jun 30, 2020Tutor
Also, are they hardwired to eachother or are you just relying on the wifi mesh?
nakenergy
Jul 01, 2020Guide
I was able to hardwire so I hardwired even though the theoritical speed with wireless is 2400 compared to 1000 ethernet connection. However, since you have to start with wireless backhaul first before hard wiring, I noticed that the speeds were also faster than AC3000 with wireless backhaul.
