tinhnghia
Feb 23, 2024Aspirant
how set up orbi rbk763 connect direct to nbn FTTC TPC provider
Hi. I am with TPG using NBN FTTC. The provider supplied NBN box with modem TP LINK ARCHER 1600. I would like to connect my new mesh wifi orbi rbk763 direct to NBN box without using TP LINK ARHER1600 ...
tinhnghia
Thanks. Yes tpg provided phone service but I did received lot of scam phone, I disconnected phone over 10 years. As your advice I can plug direct orbi to nbn box?
CrimpOn
Feb 23, 2024Guru - Experienced User
It certainly cannot hurt anything to plug it in and see what happens.
- tinhnghiaFeb 23, 2024AspirantThanks. Will do it when I back home on monday and post the results
- tinhnghiaMar 01, 2024AspirantI contacted TPG and confirmed my pppoe user name and pass. Set everything included vlan 2 and priority 1 but still no internet and led magenta
- CrimpOnMar 01, 2024Guru - Experienced User
When configuring the router using the web interface (not the 'app'), the key step is to select the box on the Internet Setup, "Does your Internet Connection require a login?" <YES>
This causes the entry boxes for ISP user name and password to become visible.
Is this how you did it?
