tinhnghia
Feb 23, 2024Aspirant
how set up orbi rbk763 connect direct to nbn FTTC TPC provider
Hi. I am with TPG using NBN FTTC. The provider supplied NBN box with modem TP LINK ARCHER 1600. I would like to connect my new mesh wifi orbi rbk763 direct to NBN box without using TP LINK ARHER1600 ...
CrimpOn
Mar 01, 2024Guru - Experienced User
When configuring the router using the web interface (not the 'app'), the key step is to select the box on the Internet Setup, "Does your Internet Connection require a login?" <YES>
This causes the entry boxes for ISP user name and password to become visible.
Is this how you did it?
tinhnghia
Mar 01, 2024Aspirant
Thanks. Yes when we login and intend using as direct router to nbn box I had to click advance - set up - internet- does your internet connection require a login - click yes then choose internet provider pppoe - username and password
