tinhnghia
Feb 23, 2024Aspirant
how set up orbi rbk763 connect direct to nbn FTTC TPC provider
Hi. I am with TPG using NBN FTTC. The provider supplied NBN box with modem TP LINK ARCHER 1600. I would like to connect my new mesh wifi orbi rbk763 direct to NBN box without using TP LINK ARHER1600 ...
CrimpOn
Mar 01, 2024Guru - Experienced User
WTF??? Sounds like TPG support was helpful. Wonder if they have advice for this situation. You cannot be the first customer to do this.
tinhnghia
Mar 01, 2024Aspirant
Tpg Technicien can only check if the username and password for my account are corrected. They can not help to set up the orbi that why I still can not successful connect direct orbi to nbn fttc box ( led magenta and no internet )
- tinhnghiaMar 01, 2024AspirantHi. Just bought an orbi rbk763 and connect to tpg archer 1600v orbi can provide mesh wifi normal. I want to connect direct orbi to nbn box ( fttc ). Set pppoe username and password provided by tpg and set vlan 2, priority 0. Unfortunately the orbi led magenta and no internet. Contact tpg they ask me to contact netgear. So annoying. Anyone did connect orbi to nbn fttc success please help. Thanks
- FURRYe38Mar 04, 2024Guru - Experienced User
Try putting the NBN ISP router back online and connect the RBR to the NBN router. Use the NBNs DMZ for the IP address given to the RBR. Does the front LED remain PINK here as well?
