MixMaster's avatar
MixMaster
Apprentice
Feb 16, 2021
How to Assign Static IP for RBS850
I have a new RBK853 system and need to be able to assign static's IP addresses for the two satellites. How do I do this? As an example since the router is 192.168.1.1 I'd like the two satellites to h...
  • MixMaster's avatar
    MixMaster
    Feb 16, 2021
    Perfect - thanks for the info.  I just asigned them dot 2 and dot 3
    Appreciate it!
    Update / clarification - It seems I WAS able to add reservations outside of my DHCP scope.  Since my scope starts at 192.168.100.x my satellites are 192.168.1.2 and 192.168.1.3
