Chuckbo
Apr 19, 2023Aspirant
How to check time on CBR750
I have a new CBK752 — the cable/router and 1 satellite. I have parent setting set up on a device to define bedtime from 10:30 PM - 7:15 AM. It's 11:15 PM, and when I look at the status of this de...
CrimpOn
Apr 19, 2023Guru - Experienced User
Chuckbo wrote:
I'm using the Orbi app. I can't find a screen that shows me what time the router thinks it is.
This appears to be (yet another) time to open a web browser to http://orbilogin.net using the router credentials (not the 'app' credentials). The router uses "admin" and a password. (not the 'app' password. not the WiFi password).
(many browsers will complain about the web site being "insecure" because of the self-signed SSL certficate. Look for an option in tiny print to "go to this web site anyway")
The current time can be found on the Advanced Tab, Administration menu, NTP settings:
- CrimpOnApr 19, 2023Guru - Experienced User
p.s. Having never enabled Parental Controls (my parents refuse to let me control them), I am certainly no expert, however......
There could be a possibility that setting allowed/disallowed times in Parental Controls is effective only when a device is not already connected to the network. This would require an experiment to prove/disprove. i.e. define a 'control' on a specific device, then see if it gets disconnected at that time when it is already active on the network.
Also, I have a vague memory of someone on the forum recently raving about Parental controls being based on GMT (or something) rather than on the local time:
(As you will see, I was not much help to him, either. Sorry.)
