MeTosa
Aug 31, 2022Follower
How to connect 2.4GHZ Devices
I have the 750 and I’m having this same problem. I was able to get to the Wireless Settings, but there is no “Broadcast SSID on 5G Channel” button. Has this process changed since the original post?
Aug 31, 2022Guru - Experienced User
So you'll need to change the power output of the 5Ghz radio to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was. Turn off ALL RBS as well during this process.
