igta
Jul 16, 2023Follower
How to connect 2.4GHZ Devices
Hi guys, July 16 2023. I tried the other posts that addressed this issue and had no luck. Even spent an hour on the phone with the customer service. I wanted to connect my MyQ garage door op...
Jul 17, 2023Guru - Experienced User
I would have posted a question to this. we could have saved you the time. Thanks for the details though.
I recommend that you sign up for the forth coming beta FW for your 8 series. You'll probably find that you'll not need to use this process anymore. đ
You're Invited! Orbi RBK75x/RBK85x/RBK86x/RBKE96x Beta Firmware Testers Needed. To participate in testing this trial firmware, please click HERE.
Enjoy.
