BukkyLam
Aug 15, 2021Aspirant
How to connect RBR850 to RBS50?
hi all, I have just ordered the RBK852 to upgrade my current ORBI system (RBK52). I have gone through some posts here and notice that the RBS50 can be used as wired satellie for RBR850. A...
Aug 15, 2021Guru - Experienced User
The RBS50 have to be connected only by Ethernet so you'll need to try to connect them first via ethernet cable.
RBS50 are not wirelessly compatible with Orbi AX.
- BukkyLamAug 15, 2021Aspirant
thanks for your reply,
yes i understand that they can be worked fine with wired connection which I am planning to do.
I was asking "how to do it".
should i plug-in the cable between the RBR850 and RBS50 then run the "Add Satellite" on 192.168.1.1?
Thanks.
- FURRYe38Aug 15, 2021Guru - Experienced User
I think just connect the RBS50 to the RBR850 then turn ON the RBS50. I believe it should auto sync and connect...
sounds good!
When I was still using the RBK52, I needed to make them sync at the initial setup, otherwsie they would not link up as a system but two individual devices.
Thanks.
