BukkyLam
Aug 15, 2021Aspirant
How to connect RBR850 to RBS50?
hi all, I have just ordered the RBK852 to upgrade my current ORBI system (RBK52). I have gone through some posts here and notice that the RBS50 can be used as wired satellie for RBR850. A...
BukkyLam
thanks for your reply,
yes i understand that they can be worked fine with wired connection which I am planning to do.
I was asking "how to do it".
should i plug-in the cable between the RBR850 and RBS50 then run the "Add Satellite" on 192.168.1.1?
Thanks.
Aug 15, 2021Guru - Experienced User
I think just connect the RBS50 to the RBR850 then turn ON the RBS50. I believe it should auto sync and connect...
