EspenK
Jun 27, 2023Follower
How to disable 5 GHz on a RBR850 through orbilogin.net ?
My new Landroid mower requires 2.4 GHz connection but this is not visible as a separate network
1 Reply
Orbi systems do not support separation of SSID networks or disabling of the radios.
So you might want to also change the power output of the 5Ghz radio to 25%. Turn off any RBS. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Be sure that 20/40 MHz Coexistence enabled.
