drakov
Jul 31, 2022Aspirant
How to disable SSID broadcast on RBR750, Firmware Version V4.6.5.14_2.0.54
Hi, I cannot see the disable broadcast SSID on the config page. Anyone know where I can go to disable the SSID on this device?
ekhalil
Aug 01, 2022Master
You can't disable the SSID of the main wifi in RBR750. You can only disable the Guest Wifi SSID.
