mike_wu2006
Oct 02, 2020Aspirant
How to enable telnet on RBK752???????
Does anyone know that how can I enable telnet on RBK752 because I did not see a enable telnet button on 10.0.0.1/debug.htm. I was thinking that the firmware just cut off this part of functions, if an...
Oct 02, 2020Guru - Experienced User
Telnet isn't supported on the UI anymore, no idea why they removed it.
You can try this:
- mike_wu2006Oct 04, 2020Aspirant
Thanks, I finally try that, but it did not work for rbk752. I was thinking if there are any other solutions for telnet.......
FURRYe38 wrote:Telnet isn't supported on the UI anymore, no idea why they removed it.
You can try this:
https://github.com/insanid/NetgearTelnetEnable
- FURRYe38Oct 04, 2020Guru - Experienced User
Should have...Worked for my 8 series...
