Electrond's avatar
Electrond
Follower
Sep 13, 2021
How to exstend my system RBR850 and RBS850
I have a router: Orbi RBR850
And two satelites: Orbi RBS850
How can I exstend this system? I need more to cover my estate with wifi signal.
But I will obtain only one wifi signal (the mesh system) so all my devices are on the same network.
Is it possible to buy the same pack as I already have, and include this. Because I see its cheaper to buy a pack with three items than only one satelite at the time. I hope you understand my question:)
1 Reply
  • FURRYe38's avatar
    You can use other 7 or 8 series RBS from other RBK kits...
    Can also use a EAX80 in pinch as well.
