raven_au
Aug 29, 2021Virtuoso
How to factory reset satellite of RBK
Hello all, So what is the correct procedure to factory reset a satellite belonging to an RBK pack by itself (RBK850 in this case)? That is without performing a factory reset of the RBR and (poss...
- Aug 30, 2021
Turn I would try turning OFF the RBS. Then go to the RBRs web page and select "Remove" from the page so the RBS doesn't reconnect there. Then turn ON the RBS wait for the WHITE front LED to blink. Press the reset button for 15 seconds then release.
raven_au
raven_au wrote:Hello all,
That is without performing a factory reset of the RBR and (possibly) other satellites.
Sorry, that "RBK853 in this case" not RBK850.
