raven_au
Aug 29, 2021Virtuoso
How to factory reset satellite of RBK
Hello all, So what is the correct procedure to factory reset a satellite belonging to an RBK pack by itself (RBK850 in this case)? That is without performing a factory reset of the RBR and (poss...
- Aug 30, 2021
Turn I would try turning OFF the RBS. Then go to the RBRs web page and select "Remove" from the page so the RBS doesn't reconnect there. Then turn ON the RBS wait for the WHITE front LED to blink. Press the reset button for 15 seconds then release.
raven_au
Aug 30, 2021Virtuoso
FURRYe38 wrote:Of course, the system, depending on how these things are tested prior to boxing, are the RBS and RBR tested pre-synced to ensure they work? However I presume they may not be as the setup process has everyone setting up the RBS during the setup wizards and they have to be synced at that time...kind of hard to tell.
Yes, performing the erase from the web GUI does indeed reset all the kit devices to factory defaults and the kit units are ready to go for the system setup. That much is clear.
I have wondered whether the kit satellites have the pre-configured system settings already set in their permanent nvram storage or whether they auto-sync on boot ... this dicussion makes me think they do auto-sync ... interesting.
I guess time will tell and hopefully resetting during early boot (once the white light has been flashing for a little bit) will be ok, ;)
Thanks
Aug 30, 2021Guru - Experienced User
Well I believe they may auto re-sync, prior to a reset of the entire system.
One thing that I've noticed since early Orbi AX, is that if I change the SSID name on the RBR, after the RBS have been turned OFF from using the prior SSID name, after I make the change on the RBR and turn ON the RBS, they seem to auto sync to the new SSID.
