Deihmos
Mar 25, 2022Guide
How to fix a bricked orbi
An update ended up bricking one of my satelites and none of the recommended solutions worked. The satelite was stuck rebooting with a flashing white light. Reset, 30/30/30 and the tftp solutions from...
- Mar 25, 2022
RBK853 but the utility should work with any Netgear router. It was very easy to use.I am so happy I don't have to do an RMA.
Deihmos
Mar 25, 2022Guide
Mar 25, 2022Guru - Experienced User
Ya some of us already know of this tool. Comes in handy for sure.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
