ajitcherian2
Nov 20, 2021Follower
How to get link speed of 2.4gbps from intel AX200 and Orbi RBK852
i recently purchased the netgear Orbi RBK852. i have an Intel AX200 (gig+) wireless card which supports 2.4gbps at 160mhz channel. however, i am only getting a link speed of 1.2gbps. how do i get my ...
Nov 20, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Check the Mfrs support site for help and information regarding the Intel branded adapter for specs and design.
Thank you
