JustRic
Dec 12, 2023Aspirant
How to improve backhaul status for RBSE960 satellites
Other than physical location of the RBSE960 satellites in relation to the RBRE960 router location, are there any specific settings on the router that might improve backhaul status on the satellites f...
- Dec 12, 2023
Move the RBS closer to the RBR...
Dec 12, 2023Guru - Experienced User
JustRic
Thank you for confirming........
Ric
- FURRYe38Dec 13, 2023Guru - Experienced User
Enjoy. 📡
