bruced_1985_
Mar 04, 2024Aspirant
How to increase coverage with rbr850 router after maxing out with 6 satellites
Currently I have maxed out the amount (6) of satellites with my rbr850 system. Is there a proven way to increase the range while utilizing these satellites that anyone can help me out with?
Mar 04, 2024Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS 🛰 to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
bruced_1985_
Warehouse space approx. 120k sq. ft.
Currently they're all spaced far greater than 30', probably closer to 50'-60'.
- FURRYe38Mar 04, 2024Guru - Experienced User
That's a pretty large area to cover. Not sure if your going to be able to fully cover that since the 8 series was rated to cover around 6k sq ft. Especially in a warehouse that Orbi wasn't really meant or designed for.
Is the system working as is currently?
- bruced_1985_Mar 04, 2024Aspirant
Yes it's supporting our needs for the most part fine as is. I'd like to try and increase the range of one satellite some so we can use it outside. Could I add a wifi extender to one of the satellites perhaps?
Yes a outdoor extender, something WAX model series could work.
