rshephard59's avatar
rshephard59
How to login to RBS750 when it is disconnected from router
I have an RBR750 with 2 RBS750 satellites.  One satellite is connected but the other is now showing as disconnected and it doesn't have an IP address assigned.  I saw a previous thread that mentioned that this might be caused by a different firmware version on the disconnected satellite, and that downgrading the firmware fixed the problem.
How to I connect to the satellite to check its firmware version and downgrade if necessary?  The satellite has no IP address and it's not reachable from the orbilogin web page.   I plugged an Ethernet cable directly into the satellite from both the router and then from my PC but it's still not accessible.
Any thoughts?
Thanks
