skott79
Mar 11, 2020Guide
How to place Orbi RBK853 Satellite in Extender mode? Abandoning this system for now.
Hi all,
Like many of you I've had a ton of issues since the last firmware update on Orbi RBK850 with constant drops and disconnects, so I'm switching back to my old Netgear Nighthawk XR700 and I would like to use one of the my satellites as an Extender but the only tutorial I could find is here: https://kb.netgear.com/000060131/How-do-I-set-up-my-Orbi-Outdoor-Satellite-in-Extender-Mode
The new RBK850 satellites don't have a power button, you just plug them in, so I'm not sure what to do to get the satellite in to extender mode. I'm assuming you hold the sync button down or the like but it doesn't seem to be syncing up with my Nighthawk.
Any help is appreciated, thanks!
RBS850s do not support extender mode. Thats only for the RBSY outdoor satellite.
Turn OFF all wifi radios on the Xr700 router. Then configure the RBR for AP mode. This will get Orbi AX working while NG gets this fixed.
skott79 wrote:Hi all,
- skott79Guide
FURRYe38 wrote:RBS850s do not support extender mode. Thats only for the RBSY outdoor satellite.
So, correct me if I'm wrong, but would I place my XR700 somewhere in my home as an extender? So I turn off the wifi radios on that, the Orbi router will still be my main router plugged in to my modem? Sorry, I've never done AP mode before so I want to make sure I'm doing this right.
Like this:
ISP Modem to>XR700 router in router mode with wifi radios disable to>RBR configured in AP mode.
Lan port on back of XR700 will connect to yellow WAN port on the back of the RBR in AP mode. Setup RBS normally. Shouldn't need any configuration on them. Might have to re-sync maybe.
Can use same SSID name and PW as before while in AP mode.The RBR will no longer be a router. Your XR700 will be.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I did this with my XR450 router for past several months.
