skott79
Mar 11, 2020Guide
How to place Orbi RBK853 Satellite in Extender mode? Abandoning this system for now.
Hi all, Like many of you I've had a ton of issues since the last firmware update on Orbi RBK850 with constant drops and disconnects, so I'm switching back to my old Netgear Nighthawk XR700 and I ...
Mar 11, 2020Guru - Experienced User
Yes. LAN to WAN on the RBR.
Is there a LAN cable connection out in the office from the XR700?
skott79
Mar 11, 2020Guide
There is no LAN connection so I’m gonna try syncing one of the satellites with the Orbi router. I hope that will work.
- FURRYe38Mar 11, 2020Guru - Experienced User
Ok, then leave the RBR with the XR700 and after syning the RBS wrielessly, you can move it to the office and it should work fine there remotely.
- skott79Mar 11, 2020Guide
That's the problem, it's not syncing wirelessly or I'm not doing it right. I press the sync button on the Orbi router when I plug it in my office but it's not working. Oh, and I now have a solid blue light on the Orbi satellite (was previously Magenta) so it looks like that's connected.
You have to press the sync button on the RBR AND the RBS on the first sync. After that you should only need to plug it in. Sounds like it's working.
Enjoy. :smileywink:
