JMM2700
Oct 21, 2020Initiate
How to separate 2.4 and 5ghz Orbi RBR750 WiFi
Trying to connect some smartplugs to the new Orbi RBR750 system I got at Costco the other week. Realized they only connect to 2.4ghz system. Been trying to follow some previous post about how to se...
Oct 21, 2020Guru - Experienced User
Be sure to post about any Orbi AX model questions and help over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Separation of SSID on Orbi systems is not supported. Not supported on Orbi AX.
Good Luck.
