mobileuser
Dec 31, 2021Initiate
How to turn off RBS850 SSID broadcasting
Hi, anyone knows How to turn off RBS850 SSID broadcasting I can't find it in the admin setting advance nor anywhere Does anyone know?
- Dec 31, 2021
Orib systems do not support disabling of the wifi broadcast. There always ON 24/7.
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Dec 31, 2021Guru - Experienced User
Thank you
- mobileuserDec 31, 2021InitiateYour reply is much appreciated
- FURRYe38Dec 31, 2021Guru - Experienced User
:smileyhappy:
