lxu2011ct
Jan 18, 2021Aspirant
How to use the ethernet port on orbi satellite of RBK753S-100NAS
I have the system RBK753S-100NAS just set up with one route (RBR750) and two satellites. The three are connected wirelessly with good connection. I connect a NAS on one of the satellite through its e...
- Jan 18, 2021
Ok, just checking.
Please remove any static IP address configurations on the NAS and set Dynamic or Auto obtain IP address configuration on the NAS.
CrimpOn
Jan 18, 2021Guru - Experienced User
lxu2011ct wrote:It seems like that in order to use the ethernet port on the satellite, the satellite has to be connect to the route by wire. is it correct?
No, this is definitely not correct.
Does the Orbi web interface Attached Devices screen not show the NAS as connected?
lxu2011ct
Yes, I cannot see the NAS on the Netgear home page of the router, neither of the satellite. Thanks.
