lxu2011ct
Jan 18, 2021Aspirant
How to use the ethernet port on orbi satellite of RBK753S-100NAS
I have the system RBK753S-100NAS just set up with one route (RBR750) and two satellites. The three are connected wirelessly with good connection. I connect a NAS on one of the satellite through its e...
- Jan 18, 2021
Ok, just checking.
Please remove any static IP address configurations on the NAS and set Dynamic or Auto obtain IP address configuration on the NAS.
Jan 18, 2021Guru - Experienced User
Can you see the NAS unit when it's connected to the RBR?
Seen others post about having the NAS connected to the RBS and they can't see it. Mines not connected to the RBS, rather behind the RBR.
- lxu2011ctJan 18, 2021Aspirant
I moved to the route and I can see it now. But it is not stable, sometimes disappeared then appeared again. One thing I noticed is its IP address: 10.0.0.200, not the one 192.168.1.x. Is this a problem? How do I force it to change the IP address to 192.168.1.x? Thanks.
- FURRYe38Jan 18, 2021Guru - Experienced User
Yes.
Means that your RBR detects a router up stream that also uses 192.168.1.1.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- lxu2011ctJan 18, 2021Aspirant
I don't have two routers. The provider is Xfinity and the cable modem is Motorola MB8600. The Netgear Orbi home router connect directly to the Motorola Modem. I think the NAS has the assigned IP address with the previous router. But it's long time ago, I cannot remember. Thanks.
