lxu2011ct
Jan 18, 2021Aspirant
How to use the ethernet port on orbi satellite of RBK753S-100NAS
I have the system RBK753S-100NAS just set up with one route (RBR750) and two satellites. The three are connected wirelessly with good connection. I connect a NAS on one of the satellite through its e...
- Jan 18, 2021
Ok, just checking.
Please remove any static IP address configurations on the NAS and set Dynamic or Auto obtain IP address configuration on the NAS.
lxu2011ct
I moved to the route and I can see it now. But it is not stable, sometimes disappeared then appeared again. One thing I noticed is its IP address: 10.0.0.200, not the one 192.168.1.x. Is this a problem? How do I force it to change the IP address to 192.168.1.x? Thanks.
Jan 18, 2021Guru - Experienced User
Yes.
Means that your RBR detects a router up stream that also uses 192.168.1.1.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- lxu2011ctJan 18, 2021Aspirant
I don't have two routers. The provider is Xfinity and the cable modem is Motorola MB8600. The Netgear Orbi home router connect directly to the Motorola Modem. I think the NAS has the assigned IP address with the previous router. But it's long time ago, I cannot remember. Thanks.
- FURRYe38Jan 18, 2021Guru - Experienced User
Ok, just checking.
- lxu2011ctJan 21, 2021Aspirant
Yes, after change the NAS static IP to dynamic it can connect to Orib constantly. Thanks.
