yanivf
Mar 20, 2025Apprentice
How two devices can be assigned the same IP when both are online?
The image below is from my device list (Orbi 950). Two MAC address same IP. firmware - V7.2.7.15
CrimpOn
Mar 20, 2025Guru - Experienced User
Bugger. Has the Orbi system been rebooted? (Not Factory Reset. Just powered off and back on again?)
p.s. It is a bit unusual to connect home speaker systems and door locks to the Guest WiFi network.
- yanivfMar 21, 2025Apprentice
Hi CrimpOn , both the alexa and august (it's doorbell camera not their lock) are connect to guest network because I'm in the process of removing them. I also found other devices that got duplicate IPs in my home network. But guest wifi or not, the DHCP should not provide the same IPs. I haven't rebooted since I saw it. I wonder if it's firmware related. I'm on the firmware with the IPv6 issue.
here are couple more examples of same IPs in the home network -- plemansMar 21, 2025Guru - Experienced User
The only time I've ever seen the same IP used was when one was offline and a different device was assigned the IP address. CrimpOn suggestion of trying a reboot to see if it fixes it would be my first step too.
Thank you both. After reboot I don't see IP duplicates.
But the main point I'm trying to make is that DHCP main role is to assign unique IPs to devices.
