webminster
May 24, 2022Luminary
How will we know?
So the pinned post says (barring issues) this fix will roll out over the next 10 days. And that after that, if you still have problems... How will we know that we've supposedly received the fix?...
- Jun 02, 2022
Fix finally applied here sometime today. Didn't seem to reboot the router. But have my admin back. Happy they were able to fix this without the reset.
hgpilot55
May 25, 2022Star
I've got the RBR850 - having the same problem. I've read the posts re: rolling out a fix - but also read about something called a 30/30/30
1. using a pin, press reset for 30 seconds. DO NOT STOP PRESSING
2. While still pressing reset (remember, do not let off) - unplug for 30 seconds. DO NOT STOP PRESSING
3. Plug back end - after 30 seconds, release pin
Bottom line, you're pressing the reset for a total of 90 seconds
When it came back online I was able to access via both the iOS app and 192.168.1.1
May 25, 2022Guru - Experienced User
One user mentioned pressing the reset button for a total of 1 minute got them back in to the web page.
