semoa79
Sep 04, 2022Initiate
HP Printer cannot connect to ORBI RBK353 satellite
 Hi there,     I'm facing an issue with my Orbi RBK353: HP printer LaserJet Pro MFP M28w can connect to router but not to satellites. I have tried both satellites: one is connected in wifi to the rout...
- Sep 05, 2022
Suggestions:
- PLease try to pair the printer with the satellite using WPS setting. Activate WPS connect in the printer https://support.hp.com/us-en/product/hp-laserjet-pro-m14-m17-printer-series/16647043/model/16647063/document/ish_4641127-4645964-16 and press the Sync button on the RBS350.
 - Please try to reserve IP address for the printer in the main router. Orbi is in AP mode as you mentioned, so the main router must be the ISP's.
ekhalil
Sep 05, 2022Master
Suggestions:
