semoa79
Sep 04, 2022Initiate
HP Printer cannot connect to ORBI RBK353 satellite
Hi there, I'm facing an issue with my Orbi RBK353: HP printer LaserJet Pro MFP M28w can connect to router but not to satellites. I have tried both satellites: one is connected in wifi to the rout...
- Sep 05, 2022
Suggestions:
- PLease try to pair the printer with the satellite using WPS setting. Activate WPS connect in the printer https://support.hp.com/us-en/product/hp-laserjet-pro-m14-m17-printer-series/16647043/model/16647063/document/ish_4641127-4645964-16 and press the Sync button on the RBS350.
- Please try to reserve IP address for the printer in the main router. Orbi is in AP mode as you mentioned, so the main router must be the ISP's.
