lisakc
Jul 19, 2022Tutor
HP Printer needs to connect to 2.4GHZ Channel
I have the latest ORBI AXE Wifi Router. My HP printer is connecting to the 5 GHZ Channel, but I need it to connect to the 2.4 GHZ channel to scan. I have tried disabling the AX on the wireless settin...
Jul 19, 2022Guru - Experienced User
Is this the 9 series Orbi?
Did you try using the IoT network to connect the printer too on 2.4Ghz?
If the printer has a ethernet port, connect it to the system via ethernet for best operation.
Contact the Mfr of the printer for help and support regarding there product as well.
