lisakc
Jul 19, 2022Tutor
HP Printer needs to connect to 2.4GHZ Channel
I have the latest ORBI AXE Wifi Router. My HP printer is connecting to the 5 GHZ Channel, but I need it to connect to the 2.4 GHZ channel to scan. I have tried disabling the AX on the wireless settin...
CrimpOn
Jul 19, 2022Guru - Experienced User
You are correct. HP9010 specs clearly show "Wireless 802.11b/g/n;"
https://support.hp.com/us-en/document/c06237779#AbT2
This means the radio in this printer can only connect with 2.4G WiFi. It can neither detect nor connect to anything else. (not AM radio. not satellite. not cordless phones...... and not 5G WiFi)
The Orbi web interface Attached Devices page (or the Orbi app Connected Devices) will show that the printer is connected to the 2.4G WiFi channel. What about going to this web site and selecting the correct software for your MacOS version:
lisakc
Jul 19, 2022Tutor
My Orbi app clearly shows that it is connected to the 5GHZ channel, I'm not sure what allows the printer to do this, but I need to figure out a way to get it to the 2.4Ghz channel.
