MartyS99
Jul 27, 2023Initiate
HP Spectre 360 losing connection to RBK 753S - found a fix
If you have a HP Spectre that keeps disconnecting, read this. I installed RBK 753S 10 days ago. It replaced fios router completely with the RBR 750 plugged directly into ONT. All was great with 30+...
schumaku
Jul 28, 2023Guru - Experienced User
I'm happy the hardware replacement worked for you. Both Wi-Fi adapters are pure 802.11ac 2x2 models, the Intel Dual Band Wireless AC 8265NGW does support up to 80 MHz bandwidth, while the Intel 9260NGW does support up to 160 MHz bandwidth. There is no obvious reason for an issue, nothing that stops both from operating properly, permitting the current driver set is in place.
