gficker
Dec 09, 2024Follower
https://www.orbilogin.net/
I was send to the adres https://www.orbilogin.net/ then I have to login but I don't know to fil in My login to the netgear site is not the same
KevinLiT
Dec 10, 2024NETGEAR Moderator
Hello gficker,
Welcome to the NETGEAR Community!
I understand that you are unable to log into your Orbi's Administration portal (orbilogin.net) using your passwords or your security questions. Unfortunately, you will need to perform a factory reset your Orbi Mesh system.
Please navigate to the link below for instructions on how to correctly:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Best,
Kevin
Community Team
