senadaruc
Jan 23, 2023Aspirant
Huge problem with Nest Cameras and RBRE960 V6.3.7.10_3.3.3 🙁
Dears, I am having a huge problem with my Nest Cameras disconnecting all the time. I have 3 outdoor nest camera 2 infoor and 1 Nest hello doorbell. I was ussing this cameras with Asus AP then...
senadaruc
Yes, I used the identical SSID, but I configured the Nest Cameras all from scratch after purchasing the ORBI.
SSI used for the cameras.
Aruc-IoT
WPA/WPA2 Personal
Thanks,
Jan 23, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- senadarucJan 23, 2023AspirantHardware Version RBRE960Firmware Version V6.3.7.10_3.3.3GUI Language Version V3.0.2.20_2.1.30.3Orbi with two satellites all on the same floor 80m2The two indoor cameras are 3 meters distance.The 1 Nest Hello ring door is 1 meterOne outdoor nest camera 2 meters.Thanks,
- FURRYe38Jan 23, 2023Guru - Experienced User
So is 80M2 the size of your home? if it is, then the RBR would be only needed for this size of home.
Having the two RBS would be too much...
Can you confirm the size of of the home and also distances between the RBR and RBS?
Satellite 1 is on 1 st floor, the second one is in the living room, and the router is at the entrance.
Here is a video showing the Router satellites and the cameras.
https://youtube.com/shorts/tYgtdb_mA9g
Thanks,
