FluidFactors018
Aug 26, 2023Guide
I am also a CenturyLink 1G fiber subscriber
I am also a CenturyLink 1G fiber subscriber, and when I was running my previous Nighthawk router, I was able to use its PPPOE + VLAN tagging as CenturyLink requires, allowing me to eliminate the free...
Aug 27, 2023Guru - Experienced User
I don't know if this will help:
I think this gets you the PPPoE setup during the installation process, however to get the final VLAN Tag configured, you'll need to use the RBRs WEB UI page to make that configuration. https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Orbi-RBR850-with-Centurylink-Fiber/m-p/2076711/highlight/true#M13729
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Or use the ISP router to handle the PPPoE connecton and it's DMZ for the RBR in router mode with DCHP on the WAN side.
