bcfleischmann
Dec 28, 2023Aspirant
I am having trouble being able to get my Verizon router to go into IP pass through
Where would I go if I don't have the radio button as stated in the user manual? I am having trouble being able to get my Verizon router to go into IP pass through and have the Orbi connect properly. ...
Dec 28, 2023Guru - Experienced User
What Orbi model system do you have?
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...You'll need to contact the ISP for help on any WAN side configurations needed on there equipment.
- bcfleischmannDec 28, 2023Aspirant
Sorry. I have the CBR750.
- FURRYe38Dec 28, 2023Guru - Experienced User
OK, is Verizon service you have Cable or Fiber? I've only seen Verizon support Fiber and if this is the case for you, them the CBR will not work for you as it's only supported on Cable ISP services, not Fiber.
For some reason my reply didn't go in this thread like I wanted it to.
I just got the Verizon 5G home internet (router using their cell towers). From what I have read on the Verizon forum, it can allow IP pass through to use your own equipment. But with me having the modem/router combo of the CBR750, perhaps this won't be possible. Sorry to confuse.
New equipment:
Verizon internet gatewayModell ARC-XCI55AX
Current equipment:
Orbi CBR750 with two satellites.
