NickP1000
Sep 13, 2023Aspirant
I am not successful in having both satellites hardwired- please help
Hello! I just purchased a new home in June and have been struggling to get to the best mesh system. I purchased this AX4200 and its fine, but not optimal. I am having trouble getting all 3 systems to...
Sep 13, 2023Guru - Experienced User
NickP1000
I have tried this already... I can't do the first 2 as the wires are within the walls of my home. the 3rd is what I am trying To do but it will not work properly
- FURRYe38Sep 13, 2023Guru - Experienced User
I recommend you take all RBS to same room as RBR or near the RBR. Using ethernet cables connect one RBS at a time to the RBR and see if they all connect there while checking the RBRs web page. CAT6 LAN cable is recommended.
