neomatrixwood
Feb 14, 2024Tutor
I am unable to connect my replacement RBS850 to my network
I am unable to connect my replacement RBS850 to my network. I have tried all manner of troubleshooting including hardwiring. In the last case it is added to the network but I cannot get log into th...
- Feb 19, 2024
And thats after a factory reset on the RBS and it not connected to anything accpet for the one wired PC? Be sure to clear out all browser caches? Would need to turn OFF the RBR.
Last resort is to try a 30-30-30 reset on the RBS.
Feb 18, 2024Guru - Experienced User
RBS for AX and AXE series have a self service web page at 192.168.10.250. Given enough time after a RBS is reset and NOT connected to any thing, this self service web page can be access at the afore mentioned IP address if a ethernet connected PC is connected behind the RBS. Might need to set a statis IP address on the PC of 192.168.10.49/255.255.255.0 to help with this. Usually 5 minutes is needed before the self service RBS web page should be accessible.
schumaku
Perfect FURRYe38 ... learning something new every day here, thank you! Found your prevous post here on the similar topic - looks much easier than what old network crowds would try.
- neomatrixwoodFeb 19, 2024Tutor
Once again thanks for the helpful responses.
I am hitting a brick wall so to speak.
I can ping the satellite via terminal.
When I try to access 192.168.10.250, even after 5-10 minutes of wait time
I get
A screenshot for good measure. I have checked the firewall etc.
- FURRYe38Feb 19, 2024Guru - Experienced User
Success!
1- Make sure all WIFI systems are off.
2- In the end I connected to 192.168.1.250 (not 10.250) perhaps accidentally
3- Firmware is now in line with rest of system.
Thank you for helping me through this!
